Posted on β12-03-2012 11:06 AM
I'm using MCX to hide certain system preferences. Everything seems to be working nicely until I tried to add a mobile profile. It tells me it can't open the "profiles" preference pane. But I tried adding com.apple.preferences.profiles to my list - but no luck.
Any suggestions?
Posted on β12-03-2012 11:41 AM
From my Mac on 10.7:
$ defaults read /System/Library/PreferencePanes/Profiles.prefPane/Contents/Info CFBundleIdentifier
com.apple.preferences.configurationprofiles
Looks like the correct bundle ID for it is com.apple.preferences.configurationprofiles
I checked on a 10.8 Mac and its the same.
Posted on β12-03-2012 12:07 PM
Of course it couldn't have a normal name like "profiles"...had to be confusing.
Posted on β12-03-2012 01:47 PM
Yeah, unfortunately Apple's Bundle IDs for their Pref Panes are kind of all over the place. Some use com.apple.systempreference, some use com.apple.systempreferences (note the plural) Some of the names of the pane don't really match what they are called in the GUI. Some are even funkier.
I had put a small script together to get a list back from Terminal of all the bundle IDs of Apple System PrefPanes just to help with having that all in one place. Try this out-
userAccount=`who | awk '/console/{ print $1 }'`
PPList=`ls -l /System/Library/PreferencePanes/ | awk '/prefPane/{ print $NF }'`
OS=`sw_vers -productVersion | cut -d. -f1,2`
for i in $PPList; do
# BI=`defaults read /System/Library/PreferencePanes/$i/Contents/Info CFBundleIdentifier`
echo "$i:
$(defaults read /System/Library/PreferencePanes/$i/Contents/Info CFBundleIdentifier)" >> /Users/$userAccount/Desktop/"$OS"_LibBundleIDs.txt
done
It exports out a text file to your Desktop.
