Terminal Notifier Script Help
  • January 31, 2013
  • 31 views
jhbush
Forum|alt.badge.img+27
I'm trying to make a template in the JSS for notifications using Terminal Notifier. I made this script quick to do some sanity checks, but it still doesn't work like I expect. Notifications don't come through for some reason.```
!/bin/bash
HARDCODED VALUES ARE SET HERE
title="$7"
message="$8"
loginwindowuser=ps auxc | grep loginwindow | grep root|awk '{print $1}'
osvers=$(sw_vers -productVersion | awk -F. '{print $2}')
gem=gem list terminal-notifier -i
# SCRIPT CONTENTS - DO NOT MODIFY BELOW THIS LINE
if [[ ${osvers} -lt 8 ]]; then
echo "10.8 not installed"
exit 0;
if [[ ${gem} != true ]]; then
echo "Terminal Notifier not installed"
exit 0;
if [ "$loginwindowuser" == "root" ]; then
echo "At Login Window"
exit 0;
terminal-notifier -message "$8" -title "$7"
  • February 1, 2013
This terminal-notifier thing is cool! Thanks for posting about it.
I've cleaned up your script a bit and it seems to work just fine:
# HARDCODED VALUES ARE SET HERE
title="$1"
message="$2"
loginwindowuser=`ps auxc | grep loginwindow | grep root|awk '{print $1}'`
gem=`gem list terminal-notifier -i`
elif [[ ${gem} != true ]]; then
elif [[ "${loginwindowuser}" == "root" ]]; then
        terminal-notifier -message "$1" -title "$2"
I used $1/$2 for command line args since I just tested it locally, not via Casper. Try it out and see if it works for you.
jhbush
  • February 1, 2013
Updated a bit more since for some reason Terminal Notifier needs to run as the console/logged in user at least once to add itself to Notification Center
user=`ls -la /dev/console | cut -d " " -f 4`
title="$7"
message="$8"
        su "${user}" -c 'terminal-notifier -message "$8" -title "$7"'
  • February 1, 2013
Now that I'm thinking about this, I would add a line to install terminal-notifier if it isn't already installed. That will ensure all 10.8 can run this script.
# Only try this if we're on 10.8+
     # Install terminal-notifier if necessary
             echo "Terminal Notifier not installed. Installing..."
             gem install terminal-notifier
     # Only send notification if a user is logged in
