Test JSS clients not checking in ??
  • November 1, 2015
  • 19 views
Forum|alt.badge.img+20
I have my Casper Test server OFF. I turn on on enrolled client computer and then turn on the Casper Test server, the client server does not check-in, i do a jamf checkjssconnection and get no connection, but client is able to ping server. .
I then restart the client computer and now the client sees the Casper test server and checks-in as intended.
Should the enrolled client be able to see the casper server regardless of the server being turned on after the client ?
Best answer by davidacland
Hi, it should be able to see it regardless. It would be no different to a client reconnecting to an internal only JSS after being off the network for a while.
It sounds like a different problem is at play.
davidacland
  • November 1, 2015
  • November 2, 2015
thanks, just what i'm thinking also, something unrelated to Casper/JSS
