Transmission - keydnap v1.5 - Keychain Backdoor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 09-02-2016 02:17 PM
I haven't seen any discussion on this:
Attackers Infect Transmission Torrent Client With OS X Malware - TorrentFreak
Another attack on Transmission, this time for creating a backdoor to the keychain data.
www.welivesecurity.com
Article 1
Article 2
Below is a script I made that kills the suspect processes and removes suspect paths/files (as per the Transmission website and Article 1).
I'm pretty new to scripting and JAMF (and system administration!), and I know that people probably aren't using Transmission, but I hope this helps someone-- even if it just provides a base so that you don't have to copy the paths from the websites :)
Also, this is the first time I've used Arrays. I think this is a pretty simple (and clear) example of Arrays for those that are overwhelmed by them like I was.
#!/bin/bash #-xe
#=============================== PURPOSE ======================================#
# Test for Keydnap v1.5 and remove it.
#============================== VARIABLES =====================================#
LOGGED_IN_USER=$(w | grep 'console' | awk '{ print $1 }')
M_PROCS=( "icloudproc"
"License.rtf"
"icloudsyncd"
"/usr/libexec/icloudsyncd -launchd netlogon.bundle" )
M_PATHS=( "/Library/Application Support/com.apple.iCloud.sync.daemon/"
"/Library/LaunchAgents/com.apple.iCloud.sync.daemon.plist"
"/Users/$LOGGED_IN_USER/Library/Application Support/com.apple.iCloud.sync.daemon/"
"/Users/$LOGGED_IN_USER/Application Support/com.geticloud/"
"/Users/$LOGGED_IN_USER/Library/LaunchAgents/com.apple.iCloud.sync.daemon.plist"
"/Users/$LOGGED_IN_USER/Library/LaunchAgents/com.geticloud.icloud.photo.plist"
"/Applications/Transmission.app/Contents/Resources/License.rtf"
"/Volumes/Transmission/Transmission.app/Contents/Resources/License.rtf" )
#================================ BODY ========================================#
## Kill malicious processes
for M_PROC in "${M_PROCS[@]}"; do
if [[ -e "$(ps -ax | grep -v grep | grep "$M_PROC")" ]]; then
echo "Killing ${M_PROC} process."
killall "$M_PROC"
echo "${M_PROC} process killed."
echo "${M_PROC} process not detected."
done
echo -e "
## Remove malicious paths and files
for M_PATH in "${M_PATHS[@]}"; do
if [[ -e "$(ps -ax | grep -v grep | grep "$M_PATH")" ]]; then
echo "Removing '${M_PATH}'."
rm -rf "$M_PATH"
echo "'${M_PATH}' removed."
echo "'${M_PATH}' not detected."
done
# ShellCheck - shell script analysis tool
# version: 0.3.8
# license: GNU General Public License, version 3
# website: http://www.shellcheck.net
- Labels:
Scripts
