Upgrade Mac OS X 10.10 Yosemite to 10.11 ElCapitan (Using Shell or Apple Script)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
11-02-2016
02:39 AM
- last edited
a week ago
by
kh-richa_mig
Hi All,
Is there any way to Upgrade Mac OS X 10.10 Yosemite to 10.11 ElCapitan through Shell Scripting or Apple Scripting.
We're using IBM BigFix Mac Software Deployment to Install/Update the applications on the endpoints. But unable to push .dmg/.pkg/.pkgs to upgrade OS from 10.10 to 10.11 using BigFix Relevance Scripting.
Limitation in BigFix using Patch Management:
BigFix patch management has ability to update the version running on same platform (For E:g, ElCapitan 10.11.3/4 into 10.11.6).
The 10.11.6 Update is recommended for all users running Mac OS X El Capitan (Earlier version into the latest one). It includes general operating system fixes that enhance the stability, compatibility, and security of your Mac.
But there should have the way using custom script (Sh or Apple Script) which can be implemented through BigFix.
Any help on this will be highly appreciated...!!!
- Labels:
Scripts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-02-2016 07:17 AM
No Casper/JSS in the equation?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-02-2016 10:36 PM
Correct @Taylor.Armstrong,
We're not using Casper/JSS for this implementation. Need to push it from BigFix.
Any Shell/Apple script which deploys this process that can be implemented through BigFix.
For E.g:
We can use sh/apple script instead of BigFix Relevance scripting for this equation.
Note: Through BigFix Relevance Scripting, we're unable to deploy it.
Please suggest...!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-03-2016 05:16 AM
Unfortunately I don't believe you're going to be able to find many folks here with BigFix experience, as this is a forum for supporting Jamf's Casper management. You may want to try posting your question in the BigFix forum:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-03-2016 06:42 AM
@prabhu490730 couldn't you write a bash script that uses curl to copy the .pkg file from a local web server to the computer then run the command line version of the installer to install the package? Maybe something along these lines:
curl -o /tmp/mypackage.pkg "http://my.domain.com/packages/mypackage.pkg"
sudo installer -allowUntrusted -pkg /tmp/mypackage.pkg -target /
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-04-2016 12:50 AM
Yes, I'm a member of BigFix Forum. But I don't think we developer has the way out to roll this equation.
I've tried there but folks not much aware of this plan, So I posted on JAMF.
I keep on checking with Mac Os X Dev team parallelly on BigFix Forum to get this done.
Thank You for your response!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-04-2016 04:37 AM
@mpermann I've tried the script for CC-Cleanup (Testing).
Script:
curl -o /tmp/CCMacSetup112.dmg "http://my.domain.com:52311/Uploads/ff4f57b56a9ec5079aeeb4c237a8bc6585d8d6c2/CCMacSetup112dmg.tmp"
sudo installer -allowUntrusted -pkg /tmp/CCMacSetup112.dmg -target /
Action shows completed, But getting Exit code 1 (Partial success; this means at least something, or possibly everything, failed to succeed). I couldn't see CC-CleanUp app installed on end-user.
Please, advise!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 11-04-2016 05:32 AM
@prabhu490730 I don't know what CC-Cleanup is. Also, in the curl command your file name has .tmp on the end, why is that? The installer command can only install a standard .pkg file not a .dmg. If you're going to try and deploy something from a .dmg file your going to need to mount the dmg so you can access whatever is on the dmg. Why don't you start with something simple like deploying a Composer created .pkg that installs Firefox or TextWrangler just so you can see if you can get it to work with BigFix or not. I don't really know anything about BigFix and have never used the software so I'm not sure I'll be much help.
