Using system_profiler with macOS Sierra
  • January 11, 2017
  • 33 views
sepiemoini
Forum|alt.badge.img+21
Hey there, all! I have an extension attribute that I've been using for a few years. With the addition of macOS Sierra, this lookup, specifically "system_profiler" and "SPSerialATADataType" no longer works for MacBookPro13,1 (2TBT3 models) in my organization. Is anyone else noticing this issue?
No results are posted via the JSS or locally when performed in Terminal. It appears that Apple has deprecated "system_profiler" and I am wondering if there is a replacement lookup that others are using.
Medium=$(system_profiler SPSerialATADataType | grep Medium Type | sed -e 's/^[Medium Type: ]*//')
echo "<result>$Medium</result>"
Best answer by sepiemoini
This seems to work in testing. Is anyone else using something similar?
Medium=$(diskutil info disk0 | grep "Solid State" | sed -e 's/^[Solid State: ]*//')
1 reply
sepiemoini
  • Employee
  • January 11, 2017
