Good people,
I work at the School of the Art Institute of Chicago (SAIC). We have been using Casper since the spring. Right now we are working on the fall semester's Casper workflow strategies. One issue we can not seem to shake is with Macs running bootcamp installed by Casper Imaging.
We are currently using JSS v8.71 with Casper Suite 8.71 and Winclone 4.1. When using a Casper workflow configuration in Casper Imaging we get some peculiar behavior. If the Mac HD has never had a BootCamp partition added, the workflow resizes and partitions the drive into Macintosh HD and BootCamp, respectively. It then installs OS X and the Winclone image on those respective partitions. After reboot the Mac OS boots fine but the Windows OS will not boot. It either gives us a blinking cursor or " A disk error occurred please press ctrl alt delete"
What's even more peculiar, if we run that same workflow again on the same machine, everything works. Mac OS and Windows OS work fine. So it seems that something is happening when the Mac HD is resized and the BOOTCAMP partition is created and then the Winclone bundle is installed.
Has anyone else had any issues with this? Any insight is greatly appreciated!
thanks,
Cosmos
