Jamf Connect and Captive Portals
emptypony61
New Contributor III
How do you guys have your road warriors login to Jamf Connect from public wifi with captive portals?
I only have a few users that do this but wonder what the Jamf Connect config setup is like.
1 ACCEPTED SOLUTION
emptypony61
New Contributor III
I think it got resolved in one of the patches now the users can connect to the wifi from the login screen and then the login screen shows the captive portal.
3 REPLIES 3
hodgesji
Contributor
@emptypony61 did you ever figure out an answer to captive portals beyond local account? I am looking for a way to connect to a guest network with a captive portal at the Jamf Connect login window.
emptypony61
New Contributor III
