I've been playing around with getting NoMAD to work in our environment. In order to have access to internal and external network we have to be connected to VPN. During initial start, NoMAD is showing Not Connected. Once I authenticate to VPN It typically takes 30-45 seconds before NoMAD authenticates and changes to connected. Somewhere in-between that time I'm getting a Proxy Authentication Required if I open a Safari window too early. Anyone know how to change that delay to be shorter or immediate? My goal is to have no possibility of a popup. I've been looking at preferences and cannot identify the right setting if there is one.
I have these set in the plist and using the Launch Agent to make sure it starts on load.
<key>LocalPasswordSync</key>
<true/>
<key>UseKeychain</key>
<true/>
<key>UPCAlert</key>
<true/>
Be the first to reply!
