Posted on 05-19-2016 05:13 AM
So far I haven't seen any chatter about problems with the latest release. Is this a case of "no news is good news"? Can anyone confirm the 802.1x Ethernet issue has been resolved? How about any other lingering issues? Have they seen their end with 9.92? I don't have the luxury of having a test environment or else I'd be hunkered down in that myself.
Posted on 05-19-2016 08:39 AM
I know there was an issue where after enrollment, Spotlight would run >100% CPU. That seems to have disappeared.
Posted on 05-19-2016 10:07 AM
@CorpTech That was resolved in 10.11.5
Posted on 05-19-2016 11:15 AM
Yes, we have experienced MDM issues, and just spoke with someone at a neighboring district with the same issue.
We are seeing that sending mobile device commands, show as sent but never actually do anything meaning they don't show as pending, failed. nada...if I install an app from the Self Service it shows pending but never installs.
Auto database backup failed to run the first night after the update.
I've checked all APNS functionality at my location, so I have a call with JAMF in the morning as there are other issues that I can't confirm are from the update at this time.
Update on 5/28/16...
The following day after this post the MDM functionality returned and appears to date to be working correctly. Must have been something at Apple that was an issue at that time, even thought the system status page showed everything in green.
The backup ran as scheduled the next night, thought it wasn't correct as there was a bad table that needed repaired. Since then it's been working as scheduled.
Posted on 05-19-2016 11:39 AM
We've just started testing 9.92... this is minor so far, but it exists.
Known and hoping it's resolved in 9.93.
Extension Attribute that is over 2 lines will left align from the 3rd line on.
Posted on 05-19-2016 12:17 PM
We are also having MDM issues. Severely high CPU utilization - I even shut down the server and added a couple of virtual procs - system runs fine for a while, then mysql goes nuts!! We have to restart tomcat once every few hours.... We're also seeing missing pages in the interface.
Posted on 05-19-2016 12:21 PM
@shcsdrce is your JSS on a Mac or Windows server?
Posted on 05-23-2016 04:34 PM
@mahughe Please post your end result? If it is a defect please post the number as well. thank you!!
Posted on 05-26-2016 12:45 PM
just upgraded to 9.92 and no longer can mount Master Repository. I can mount manually through terminal using native and Jamf tools, but getting mount errors in all the Jamf apps (CasperAdmin, Self Service, etc)
Posted on 05-27-2016 01:50 AM
@bcldonnelly try to change "full.domain.name" to "just-domain" like suggested here or there
Posted on 05-27-2016 08:18 AM
@bcldonnelly having the same issue with mounting the fileshare distribution point here, I believe. fwiw
Posted on 05-28-2016 07:13 AM
Posted on 06-23-2016 06:25 PM
Confirmed, had to remove the domain name from the "Workgroup or Domain" field under the "File Sharing" tab after upgrading to 9.92.
Posted on 06-23-2016 06:56 PM
Same issue here, I fixed it about 10 minutes after upgrading. We just upgraded our JSS last Tuesday.
