Posted on 02-11-2013 08:44 AM
I have a machine (which means probably I have a lot of machines like this) that I absolutely cannot get my configuration settings to reliably work on. Specifically, the user profile settings are applied, but the system level settings do not appear to be applied. At one point we had both MCX and configuration profiles on these machines. I have since tried to remove the MCX settings, but I suspect there is some remnant of these old settings that is interfering with applying settings from the configuration profile. Any ideas?
Posted on 02-11-2013 09:30 AM
Check the log files on your JSS server. Are there any errors that it can't see the apple push notification server? (That's usually gateway.push.apple.com:2195 )
Posted on 02-12-2013 09:55 AM
Don't see anything in the JSS log about that. In any case, the profiles are getting installed, it just isn't managing the preferences.
Posted on 02-13-2013 01:02 PM
I'm having a similar problem. We had a couple of Managed Preferences set during our Jump Start, I then set up a Configuration Profile to do the same thing and removed the Managed Preferences. I cannot get the new profile to work consistently on our test machines.
Posted on 02-15-2013 05:42 AM
In order to get the affected machine back in service, I'm going to back up the user's data and re-image the machine. I don't see much other choice, since this doesn't seem to have an easy answer.
Posted on 02-15-2013 06:15 AM
Try ```
sudo jamf enroll
Then a restart.
Once restarted, it may not be enrolled. So run the command again.
If MDM cert is there then run: ```
netstat | grep tcp4
You should get something about apple courier & port 5223 if successful.
Posted on 02-19-2013 05:57 AM
Nope, didn't work. My user still has access to all of the preference panes that I have restricted. Again, the profile is getting installed. The preferences just aren't being applied.
EDIT: Also, I know that MCX settings are somehow still being applied to the machine, because when I log into a newly-created user account, some preferences panes are hidden (not disabled), which is something that we used to manage with MCX before moving everything into configuration profiles. I have no idea where these settings are coming from, since they are no longer assigned in the JSS, and I have run```
dscl . -mcxdelete /Computers/localhost
dscl . - mcsdelete /Users/<myuser>
``` but the MCX settings continue to be applied.
Posted on 02-19-2013 07:20 AM
@nextyoyoma, when you turned off the MCX settings in the JSS, did you set them to "Make this Preference unmanaged" or did you simply delete them from the JSS? Technically you're supposed to do the former. Doing the latter may get you into a situation like the one you're experiencing, where the settings may stick to a Mac that has had them applied already. That's not always the case, but I have seen "ghost" MCX settings that simply won't go away until the original MCX is set to Unmanaged and applied to the machine in question.
In addition to the dscl commands above that you ran, have you deleted the entire 'Managed Preferences' folder in /Library/ from the Mac and restarted?
Posted on 02-19-2013 07:57 AM
@mm2270 - I initially did that, but once I was reasonably certain the "unmanaged" version of the preference had been applied to every machine, I unscoped the MCX prefs entirely.
I have tried deleting /Library/Managed Preferences, but the issue persists after restart.
Posted on 02-19-2013 11:17 AM
Ok, issue persists even after re-imaging. Maybe this is because there were MCX preferences applied to the machine we used to generate our base image? If so, I guess we will never be able to reliably manage any preferences. Extremely frustrating.
EDIT: double post.
Posted on 02-19-2013 12:11 PM
We had the same problem with Config Profiles being applied inconsistently last summer. We scripted what we could and abandoned the Config Profiles for now. We'll give it a try again when 10.9 is released.
Never found the MCX things we wanted to do were reliable either, so never used them.
Posted on 12-09-2013 10:53 AM
@nextyoyoma - Since the MCX settings were applied when a new user was created, did you check to make sure the MCX preferences are not still in the /System/Library/User Template/ preferences.
