Distribution point won't mount when trying to replicate
BigToeKnee810
New Contributor II
Hello!
We are still configuring our instance and we are having issues replicating. When trying to replicate I noticed that we have this error via the log:
-- Replicating to local drive CasperShare  6/8/16 10:15 AM --
2016-06-08 10:15:02: Comparing files based on size
2016-06-08 10:15:02: Removing unwanted packages...
2016-06-08 10:15:02: Removing unwanted scripts...
2016-06-08 10:15:02: Copying create_helpdesk-1.0.pkg...
2016-06-08 10:15:02: Copying Google Chrome 51.0.2704.84.pkg...
2016-06-08 10:15:05: Copying Microsoft Office 2016.dmg...
2016-06-08 10:17:14: Copying OSX 10.11.5 5.17.16.dmg...
-- Unmounting ex:///CasperShare  6/8/16 10:21 AM --
2016-06-08 10:21:43: Writing Casper Data XML...
2016-06-08 10:21:43: Finished.
-- Replicating to distribution point  https://jss.host.com/CasperShareDAV  6/27/16 2:24 PM --
2016-06-27 14:24:15: Comparing files based on size
2016-06-27 14:24:15: Mounting https://jss.host.com/CasperShareDAV...
2016-06-27 14:24:23: ERROR: The distribution point could not be mounted. The replication operation will stop
2016-06-27 14:24:23: Finished.
-- Unmounting https://jss.host.com/CasperShareDAV  6/27/16 2:24 PM --
2016-06-27 14:24:47: Comparing files based on size
2016-06-27 14:24:47: Mounting https://jss.host.com/CasperShareDAV...
2016-06-27 14:24:52: ERROR: The distribution point could not be mounted. The replication operation will stop
2016-06-27 14:24:52: Finished.
-- Replicating to distribution point  https://jss.host.com/CasperShareDAV  8/3/16 11:19 AM --
2016-08-03 11:19:23: Comparing files based on size
2016-08-03 11:19:23: Mounting https://jss.host.com/CasperShareDAV...
2016-08-03 11:19:34: ERROR: The distribution point could not be mounted. The replication operation will stop
2016-08-03 11:19:34: Finished.
-- Unmounting https://jss.host.com/CasperShareDAV  8/3/16 11:19 AM --
So the issue I am noticing that I only have a folder named CasperShare not CasperShareDAV. Is there away to change this?
8 REPLIES 8
roiegat
Contributor III
Yes. Go into the Distribution Point settings and go under the "File Sharing" Section and change the share name to CasperShare.
Good luck.
BigToeKnee810
New Contributor II
I don't see where to do that. I'm a noob.
BigToeKnee810
New Contributor II
So our distribution point is Cloud based and a local Mac. I am assuming you mean going to server and enabling that for File Sharing.
But that has been done. The issue is Casper Admin is not pointing to that location and pointing to /CasperShareDAV which does not exist.
perrycj
Contributor III
@BigToeKnee810 I think he meant, in the JSS go into computer management > file share distribution points and change the DP settings in there.
Once you click on the DP you want to edit, you'll see the different tabs for various settings. One of them is the name of the share on your DP.
BigToeKnee810
New Contributor II
But this should effect the JDS? I am trying to replicate the JDS not a File Distribution Point. I created one still cannot connect.
perrycj
Contributor III
@BigToeKnee810 Oh, a JDS? I didn't know that. They have their own settings in the JSS, near file share distribution settings in computer management. Have you poked around in there to check the share name(s)?
BigToeKnee810
New Contributor II
@perrycj Yep, their isnt an option to change it.
chrisdaggett
Contributor II
Figured it out*
