Posted on
11-28-2018
12:06 PM
- last edited
3 weeks ago
by
kh-richa_mig
We can pull VMware Fusion serial number.
Is there a way to identify whether it is installed with a VMware Fusion Pro license?
Will circle back to update thread if we come up with something.
Thanks,
Don
Posted on 07-27-2020 12:22 PM
Seems like a good thing to ask your friendly neighborhood VMware rep... I'll try to ask mine when I get the semi-annual email, usually around the time my licenses are up for renewal. Hopefully there's a real simple differentiator!
Posted on 07-27-2020 12:59 PM
Don't use VMware but if they use XML files like Parallels you can probably adopt something like this
All that data should be in the file VMware puts it in
