Posted on 06-28-2021 12:22 AM
I previously used a PLIST for managing Chrome and Edge including pushing 2 extensions for all users. This worked, it pushed them in an active state, no problems.
Seeing you can now get nice JSON config files that let you toggle any setting within Jamf I switched to that but when push the 2 extensions they are both loaded, locked but disabled.
Its my understanding that you can add keys in an additional plist to configure extension settings, including if its enabled or disabled but so far not been able to find how.
Anyone know?
Posted on 06-28-2021 04:26 AM
I have Jamf manifests for Chrome and Edge here to create configuration profiles that will install and enable extensions. These may get you what you need.
The manifests are here:
https://github.com/Jamf-Custom-Profile-Schemas/jamf-manifests
Instructions are here:
https://github.com/Jamf-Custom-Profile-Schemas/jamf-manifests/wiki
Posted on 12-07-2022 08:39 PM
Thanks @talkingmoose . I have those already, figured out what the problem is. The extension im trying to push is Chrome. Im using Edge. You need to click on the "allow extensions from other stores" link to enable them, after that the push works. So now im searching for a way to push "allow extensions from other stores" to all devices.
Posted on 12-08-2022 06:02 AM
Haven't tested, but looks like the key you need for your Edge management configuration profile is here.
Posted on 02-10-2023 08:04 AM
Not sure if you've found your solution yet, but what worked for me to select the "allow extensions from other stores" was using Jamf Composer and specifying the setting "Monitor File System Changes". After that I went into my Microsoft Edge and selected the "allow extensions from other stores" option and then finished the Composer image. Then I made that into a DMG, put it in Jamf and also specified the FUT and FEU to allow for new and existing users to have the option selected. Best of luck!
Posted on 07-20-2023 08:12 AM
Thank you so much for these, there's almost nothing on the internet about browser extensions on Jamf but these worked perfectly!
Posted on 11-20-2023 01:44 AM
Does anyone of you know the key for safari extension to allow access to all websites?
2 weeks ago
Not sure if you managed to get this resolved, but using this plist works great. You don't need to add other setting on the standard Edge config profile, not even allow this extension. This is great as it can be pushed separately from the Standard Config profile for Edge.
