Posted on 05-06-2014 06:21 AM
is there a simple way to set the default to single sided printing for canon fiery printers? Keeping in mind the end users don't have admin rights.
Posted on 05-06-2014 06:35 AM
I typically do that with lpadmin. This is the command for a Fiery driving a Xerox XC570, but should be similar for a Fiery driving a Canon printer:
lpadmin -p <printername> -o EFDuplex=false
You can use the lpoptions command to find what options you can set:
lpoptions -l -d <printername>
Throw in a pipe to grep to look for duplex options and you might be in luck. Just test the settings to see what you get:
lpoptions -l -d <printername> | grep -i duplex
As always, TEST, TEST, TEST.
Posted on 05-06-2014 06:50 AM
Here's how I did it: http://macmule.com/2013/07/16/canon-imagerunner-advance-c5240i-b2-printing-duplex/
