I need help with a Basic script (please)
scentsy
Contributor
I'm trying to run a script to check first if a file is already on the mac I want it to quit, and if the file is not on the mac to go ahead and install it.
At the moment I have a policy that copy the file to /tmp/CB/file.pkg than it gets installed.
( file.pkg gets installed into "/Applications/file.pkg")
But I want it to skip install if the file.pkg is already installed on the "/Applications/file.pkg"
I told you it was basic =)
this is what I have so far:
installer -pkg /tmp/CB/file.pkg -target /
1 ACCEPTED SOLUTION
lkrasno
Contributor II
Many examples available online for "bash if" (and other conditional statements)
pkgDir="/tmp/CB/file.pkg"
if [ -d $pkgDir ]; then
    do this
    do that
7 REPLIES 7
lkrasno
Contributor II
    do this
    do that
scentsy
Contributor
that was fast! thank you.
one last question I want it to exit if the file is on the /tmp/CD/file.pkg and install if its not there....does the "exit" looks correct? (do I need a "exit 0" or "exit 1")?
thank you very much!
    exit
lkrasno
Contributor II
You're on the right track, and yes, ideally you'll want to use the appropriate exit code
scentsy
Contributor
got it thank you again!
donmontalvo
Esteemed Contributor III
Would probably use -e unless that's a non-flat PKG.
https://donmontalvo.com
mschroder
Valued Contributor
A few comments:
  • Good idea to save resources and not do the transfer and install if not needed.
  • Instead of running the script again and again, just to find out the package is already there you could make a smart group that contains the devices that don't have the package installed, and run it only on these.
  • Non-zero exit codes usually indicate that an error occurred. It is useful to stick to that convention and don't use non-zero exit codes to signal something else.
  • A package in /Applications? Sounds weird to me.
Cheers,
Matthias
scentsy
Contributor
@mschroder thank you for your comments =)
yes you are right a package in Applications doesn't make sense =) I didn't explain it correctly, so the package gets download it to /tmp/CD/file.pkg than the scripts run the installer and what it actually happens the file.pkg installs the application into /Applications =)
I will also try your suggestion on using a smart group.
Thank you very much!
