is there any way to configure permissions within system preferences > security & Privacy > Automation
  • October 30, 2018
  • 7 views
is there any way to configure permissions within system preferences > security & Privacy > Automation, so I can trust a modified version of talking moose's script that will auto set up users outlook email accounts.
As it presently gets still hits sandboxing for approval to modify outlook, during its setup process, which for many of our end users I suspect will possibly disapprove the rights to configure it.
If I can overcome this hurdle, I wont have to launch and approve the setup for each users device after they deploy their enrolment configuration.
1 reply
  • October 31, 2018
Yeh I'm having the same problem with my network drive script.
I don't want the users to have to OK it even if it's just once per machine.
