Jamf Remote running script parameter number bug
cbd4s
Contributor II
According to the Admin Guide doco (10.14) as well as the Jamf Remote app, it looks like the script options in Jamf Remote still has Parameter 1 to 8.
I think these parameters should be from 4 to 11 same as Parameter Labels in the jss web console.
2 REPLIES 2
sdagley
Esteemed Contributor III
@ccsben You should file this as a Feature Request as that's a better way to report a flaw than a discussion thread.
cbd4s
Contributor II
