Posted on
11-06-2017
06:52 AM
- last edited
Tuesday
by
kh-richa_mig
Is anyone using Datadog or a similar product for monitoring a clustered environment? I would like to find a monitoring solution to consolidate the metrics for ease of use.
Solved! Go to Solution.
Posted on 01-05-2018 10:07 AM
Hey @m.donovan Ive been using DataDog for about 6 months to monitor my Master WebApp, Admin Webapp, LoadBalancer and mySQL database. It's been a great tool. I highly recommend it. It's definitely helped me recognize issues and resolve them.
All their docs walked me through everything nicely. They have templates for a lot of common apps, like haproxy, mysql and tomcat.
I organized mine left to right in columns. MySQL, HaProxy LB, MasterWebApp, AdminWebApp.
Posted on 11-08-2017 06:10 AM
Hello,
Datadog makes it easy to get setup and started. We also have some case studies detailing different customer environments that can be found here:
https://www.datadoghq.com/customers/
And you can find information on getting started here:
https://docs.datadoghq.com/
If you want additional details feel free to open a support ticket with:
support@datadoghq.com
Hope that helps!
Andrew
Posted on 01-05-2018 12:35 AM
Definitely looks like good stuff...should give NewRelic a run for it's money. ;)
Posted on 01-13-2018 08:31 AM
@ssrussell Wow! Thanks for the info. I have been playing around with it for a few months now but have not done anything with the integrations. Mainly just monitoring CPU and Memory usage. I just got the okay to upgrade to the pro version as soon as that gets done I will dive in.
Posted on 01-13-2018 09:03 AM
@m.donovan if you ever get stuck or need screenshots of any configs feel free to reach out. Thanks.
Posted on 01-13-2018 11:11 PM
Whoa, this looks very nice and something to consider as we develop robust monitoring.
Has anyone tried 'rolling their own' solution with something based on Zabbix?
