- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on 10-19-2012 10:32 AM
I want an extension attribute to tell me the version of the Oracle installed (new) Java JKE 7.
So a little script goes like this:
if [ -e /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java ]; then
result="$(/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version)"
echo "$result"
Problem is -- I can't seem to grep the results, although my output is like this:
java version "1.7.0_09"
Java(TM) SE Runtime Environment (build 1.7.0_09-b05)
Java HotSpot(TM) 64-Bit Server VM (build 23.5-b02, mixed mode)
I can't output this to a text file either.
Any ideas?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-19-2012 11:43 AM
Got it...
/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version 2>&1 | grep "java" | awk '{ print substr($3, 2, length($3)-2); }'
had to play around with some things seen elsewhere in discussions -- thanks for everything - Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-19-2012 10:42 AM
That's a common problem with the java -version command. Try to pipe stdout and sterr to the grep, like so-
2>&1 | grep "regex"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-19-2012 11:33 AM
Thank you! so, if I:
my output is:
That's good enough for smart searching -- but I'm not skilled enough at "cut", et. al to get this trimmed down to something like:
1.7.0_09
My other thought was that since the new Java is a preference pane you should also be able to grep the output of:
system_profiler SPPrefPaneDataType
But that seems a tad more complicated.
Any thoughts?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Got it...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 10-22-2012 10:02 AM
Not entirely sure where I found this, but here's the EA I had running:
#Check if java_home is defined
javaHome=/usr/libexec/java_home 2> /dev/null
if [ ! -z $javaHome ]
then
vers=java -version 2>&1 | grep "java version" | awk '{print substr($3,2,length($3)-2);}'
echo "<result>$vers</result>"
echo "<result>Not Installed</result>"
Then I created an advanced computer search for Java version is not blank, ticked Java version as a display field, and voila.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-14-2013 06:21 AM
The complicating factor is that you can get differing results based on what you check. It's incredibly common for a machine to report 1.7 when checking the plugin, but 1.6 when checking Java home.
So I look for both in two separate EAs.
Plugin:
java_version=`/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version 2>&1 | head -n 1 | cut -d" -f 2`
echo "<result>$java_version</result>"
Runtime:
#this is to find the current version of java on a machine.
if [ -e /Library/Java/Home ]; then
javaVersion=`javac -version 2>&1 | sed 's/.*javac //'`
echo "<result>$javaVersion</result>"
(btw, no really good reason I'm checking javac on the latter - just am)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-14-2013 06:48 AM
Remember that if you capture plug-ins for inventory you actually already have the Java Internet-Plugin version without an extension attribute.
It's identified by the name: JavaAppletPlugin.plugin
Oracle version numbers are identified by Java 7 Update x (where x is the update). Computers with older Apple Java plug-ins identify with numbers like 14.0 or n/a for older Java installs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-14-2013 12:48 PM
Thanks for the EA, just what we needed!
**$** /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/
1.7.0_11
https://donmontalvo.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 05:14 AM
Not working for me...
Run this from the command line and
I get 1.7.0_11
Here is my extension attribute and I am still not getting anything displayed in that field
result="$(/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version 2>&1 | grep "java" | awk '{ print substr($3, 2, length($3)-2); }')"
echo "<result>Not installed</result>"
any ideas? Java is installed on the test box where I run this...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 06:55 AM
Here's another way and it avoids all the grepping and such...
PLUGIN_DIR='/Library/Internet Plug-Ins'
PLUGIN_NAME='JavaAppletPlugin.plugin'
# Verify plugin exists
if [ -d "$PLUGIN_DIR/$PLUGIN_NAME" ]; then
#echo "Found $PLUGIN_DIR/$PLUGIN_NAME"
# Verify plugin info plist exists
if [ -f "$PLUGIN_DIR/$PLUGIN_NAME/Contents/Info.plist" ]; then
#echo "Found $PLUGIN_DIR/$PLUGIN_NAME/Contents/Info.plist"
version=`defaults read "$PLUGIN_DIR/$PLUGIN_NAME/Contents/Info" CFBundleVersion`
echo "<result>$version</result>"
echo "<result>Plugin Not Directory</result>"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 07:01 AM
Can you clarify what you mean by "not working"? That command is giving you the correct result for what version should be at that location, and your script returns the same value wrapped in result tags.
Remember that EA's are captured during recon. Did you do a recon on the box before checking the EA again?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 07:06 AM
You might also want to take a look at Rich Trouton's post on his blog about Java EAs:
http://derflounder.wordpress.com/2012/10/31/casper-extension-attribute-scripts-to-report-java-browser-plug-in-info/
I'm using his method to find the vendor and the other method he posted from Christoph von Gabler-Sahm to find the version. Both are working as expected for me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 07:08 AM
mzago, yes... but the EA is still super handy for reports (try getting a plug-in to show up in inventory search results). Also, that plug-in section in inventory doesn't tell you if it's an early-access build (we've got devs).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 07:13 AM
@JPDyson
by not working i mean http://cl.ly/image/1H383Y0Z0r0z nothing is showing up, even when it works on the command line.
@stevewood
Awesome find, thanks will have a look pronto, that is exactly what I want to do
@JPSyson
Don't have devs here just students and a typing programme for kids and math software for the big kids that needs java.
Thanks guys
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-16-2013 07:26 AM
@rpotvin, I don't know what to tell you - I copied your script into an EA on my jss, ran recon on a machine that has Java installed, and the field populated fine.
http://cl.ly/image/2B1i2A05271w
http://cl.ly/image/341H1g3s3Z2U
(note that the text is wrapping in the script field; i just copied and pasted your script exactly as typed above)
