JSS 8.6 and Casper Suite Applications
kink80
New Contributor
If I upgrade our JSS server from 8.52 to 8.6 will I still be able to user the older Casper Suite applications (i.e. Composer, Admin) or will I have to upgrade the applications as well?
5 REPLIES 5
jarednichols
Honored Contributor
You'll need the new versions. Though, Composer you can keep as it doesn't directly talk to the JSS. However, Composer 8.6 squashed that re-naming bug so you'll probably want it.
kink80
New Contributor
Thanks for the response! So if I upgrade the Casper Suite to 8.6 will the upgrade preserve all of my preferences and packages created with the older version?
jarednichols
Honored Contributor
Yes it will. Though obviously, test test test.
kink80
New Contributor
Will I have to update Casper Imaging as well for it to work with the JSS 8.6 server or will Casper Imaging 8.52 still work?
chris_kemp
Valued Contributor
You should update Casper Imaging as well.
