Mismatch in Numbers of Smart Group - Dispalyed vs. Actual
MTFIDjamf
Contributor II
Seeing an dd issue which popped up after the 9.96 upgrade. We have numerous Smart Groups setup on the dashboard. All seem to have accurate numbers except for one.
The group for OS X El Capitan.
Dashboard:
9c64c3da9c3e4b3b9c9d964bc8a22cee
After clicking on the count it brings us to the Smart Group machine data where it shows this:
ff9e9b34e3eb4ff78440787e9f579e2b
Not sure why this is happening. No other displayed SG is doing this.
Here is the criteria for the SG, very basic:
2561d2d7ebbc4a6cbd8d730be663a13e
Anyone have any ideas/thoughts?
8 REPLIES 8
PeterClarke
Contributor II
YEP - Needs to be: Operating system: 'like' 10.11.6
Since: 'is' is trying to do an Number comparison,
and 10.11.6 is not a Number !
10.11 is a number, 10.11.6 is not a number - it's a string… so you need to use the 'like' operator…
MTFIDjamf
Contributor II
@PeterClarke The SG was originally set to 'like' and 10.11, and 10.11.6.... same result.
I also have a Yosemite SG set both ways and it displays the same as the SG when clicked from the dashboard.
Same for Sierra.
Only the El Cap SG is doing this. One number on the dashboard, another shows when you click on it...
Has only been like this since upgrading to 9.96. Was working fine before the upgrade (dashboard and SG matched).
El Cap with 'like':
b195056de4374ec99d344dbbe3a3a859
62588b041b5e4419bdb4b7d09a8e5f2b
3a4b59201d374960a939ba8ba4fe8294
Yosemite (working fine):
f95c6c92360d48b7944d036dcebf8d3d
9172a4882b104b25920bc4b5d1913035
2858de09698f4b93bf4737d124d2393f
pcrandom
Contributor
Not in front of my JSS right now, so I can't test it myself, but do do you have some El Capitan systems in different sites? Maybe the number on the dashboard includes everything but the number in the view list only includes the current site, if it's not set to all sites. Also, which number appears when you view your list of smart groups?
MTFIDjamf
Contributor II
@pcrandom We only have one site in use, not multiple. The higher number only appears on the front dashboard page, everything else shows the lower number. Any way that I setup the SG, the dashboard number is always higher than the actual SG. Really odd.
mpermann
Valued Contributor II
@MTurnerFMRCO I just wanted to say that I see the same thing with our JSS. We don't use sites either. So it's not just you that see a discrepency with the numbers reported on the dashboard. I mainly use the numbers reported on the dashboard as estimates and not necessarily the actual numbers.
strider_knh
Contributor II
We have a smart group that says there are three items in it but then only shows one. No, there isn't a filter or anything to limit it.
5d1659a51eef4a1686667b575366531d
MTFIDjamf
Contributor II
@mpermann Interesting. I may have to start looking at them in the same way. Whats even more odd is the fact that only this one SG, for seeing the El Cap devices, is doing this. I have Yosemite and Sierra SG's set the exact same way and they are fine. Same goes for every other SG (I added each to the dashboard and confirmed). Only this El Cap one is doing it and only after installing 9.96.
donmontalvo
Esteemed Contributor III
Found this thread when searching for a similar issue...wanted to leave this here just in case it is relevant...maybe a regression?
PI-002230 Smart Group numbers inaccurate between dashboard and group (Discovered in 9.81)
https://donmontalvo.com
