Posted on 12-06-2011 11:10 AM
Hey Casper Braintrust,
Have been having some odd problems with some complex installations to 10.7.x systems. Specifically with my Xcode installer and Checkpoint FDE. I created these to create a temp folder in the /tmp location and place the required packages to be installed within it. Then I called the installers with a post flight script. These have worked great in Snow Leopard, but no longer in Lion. I am sure is has to do with changes to the new OS. Is anyone out there doing similar installations for your more complex installs and found a solution to doing these installations.
Thanks
Paul Austin
End User Computing, Platform Engineering
Wells Fargo | 1525 West W.T. Harris Blvd | Charlotte, NC 28262
MAC D1112-036
Tel 704 427-0903
Posted on 12-06-2011 12:41 AM
Are you seeing any error messages?
Do they install normally ok?
Regards,
Ben.
Posted on 12-06-2011 12:51 AM
Both of the installations fail. According to the install.log they usually
fail inside a sub package script. The one that is driving the most crazy
at the moment is CheckPoint FDE. The installer for FDE has an "isp" file
that has to coexist in the same directory as the installer to do a silent
install with the correct settings. The installer native installer from the
vendor is a mpkg. I placed the mpkg and the isp filed into
/tmp/fde_install and captured them with Composer, then created a post
flight script to install the fde mpkg package. This works great in 10.5
and 10.6. 10.7 blows up running a script in one of the sub packages inside
the main installer that references the isp file that is in the same tmp
directory. I am wondering if Lion is running the installer in a "sandbox"
type mode so it can't fully read the isp file. Funny thing, is this only
fails if I run the package through casper. Policy, Self Service or Remote
all fail. If I run the installer from the desktop, it runs like a champ.
Paul Austin
MAC D1112-036
Tel 704 427-0903
paul.austin at wellsfargo.com
Posted on 12-12-2011 03:16 PM
Try putting the stuff you would have dumped in /private/tmp inside the
On 7 December 2011 05:10, <Paul.Austin at wellsfargo.com> wrote:
package's Resources, then do what needs to be done in the post scripts
using the $1 variable. For example:
postflight:
installer -target / -verbose -pkg $1/Contents/Resources/XCode.mpkg
Posted on 12-13-2011 05:52 AM
A good example of this kind of workflow is the Parallels deployment wrapper. When deploying virtual machines, the wrapper's postflight script will mv them into /Users/Shared/Parallels directory.
Doug Brown wrote:
For most deployments we've been installing into the /tmp directory but it's definitely time to review the workflow and adapt the above.
Don
