Posted on
03-11-2019
06:28 PM
- last edited on
03-04-2025
06:55 AM
by
kh-richa_mig
A faulty patch resulted in an alias to the Applications folder on the root level of the drive. I would like to remove it via the "Files and Processes" option in a policy. This works fine for regular files and folders but it seems to not touch an alias.
Is there some special way I have to address an alias?
Posted on 03-12-2019 06:10 AM
@vanschip-gerard You should be able to use rm, but a command used specifically for this purpose is "unlink":
/bin/unlink /path/to/symlink
