What's the best way to get a script to run after an install/reboot from SS?
I tried to bundle a FB package w/ the createOSXInstaller for ML, but the local accounts get messed up. I found that when I use just the CreateOSXInstaller w/o any additional packages it's fine. I also created a FB Package that just has 'exit 0' as the only thing it does and it messed up the accounts as well.
Since there is limited support for using the OSXInstaller.pkg, I figured i would look for ways around the bundling FB with it.
Do anybody have any suggestions on how I can get it to run a script at boot to setup the stuff I need before getting the final login prompt?
