Softwareupdate --ignore replacement in Big Sur?
AJPinto
Esteemed Contributor
Apple has retired --ignore from softwareupdate in big sur. Does anyone know if there is any replacement or similar function that was added in Big Sur or are we out of luck for ignoring updates going forward?
2 REPLIES 2
pete_c
Contributor III
It appears that Apple is only going to allow a deferral period of up to 90 days.
File feedback on this matter.
Cayde-6
Out of luck, Big Sur will only allow a deferral of 90days from the point of the patch release.
File feedback and Apple Care tickets to highlight your dislike of this.
