updater...
jmclaughlin
New Contributor
Hi everyone, I've created a dmg of an Adobe installer and Casper Admin refers to it
as an Adobe Updater instead of as a whole installation. The installer is
Adobe CS4 Web Premium and it contains two discs. I followed the
instructions off JAMF's site to consolidate all folders. I copied all
payloads into one folder and I copied all extensions into another folder. I also changed the Setup.xml file to reflect the change in folder name. What else do I need to change so that Casper sees the installer correctly?
John McLaughlin
Technical Support Specialist
Newton Public Schools
0 REPLIES 0
