Using Recon Network Scanner to take unmanaged Macs to managed state.
  • November 19, 2010
  • 7 views
We are having more then 100 unmanaged Macs in the environment. i am running Recon Network Scanner to take them back to the managed state. in the Global Scan Options there is a check box Do not scan IPs of computers already in the JSS something we should check?We wants to save the Recon documents and edit it over time to cover the subnets that we find "Unmanaged" computers on.
Is it so that running Recon set computers to Managed?
Is any one earlier gone through like this? Please suggest.
Regards,Vinay Washimkar
1 reply
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • November 19, 2010
The inventory process can take a while when run on many Macs. This setting
On 11/19/10 2:31 PM, "vinay washimkar" <vinaywashimkar at hotmail.com> wrote:
is useful when you are interested in inventorying computers that are not
in your JSS and you want to reduce time. Once a machine is in the JSS you
can schedule a policy to routinely inventory your Macs to keep your JSS
up-to-date.
William Smith
Technical Analyst
Merrill Communications LLC
(651) 632-1492
