Shared iPads max users
  • September 19, 2022
  • 15 views
I have shared iPads set as 6 max users in the DEP profile (the profile for shared classroom iPad carts).  But there always comes a point when users start having login issues, or resetting pins don't work.  Usually because the device has no more memory or storage which gets solved by deleting the user profiles - which are way over 6.  Why are the devices allowing more than 6 users?  I thought they were supposed to delete the last profile used if a user logged in that went over the max allowed?  What am I doing wrong?
And if this post is in the wrong place, could someone point that out also?  I can't find the 'question and answer' box.
1 reply
  • September 29, 2022
Sorry it's an Apple Problem.
It's not working fine that configuration.
