Tips for swtiching off Nomad for Jamf Connect and Okta
binjali
Contributor
We use Okta as our main identity provider, and I'd like to leverage that alongside Jamf Connect to get Zero-touch working in my environment.  is there any advice for disabling Nomad and getting Okta and JC working nicely together?
1 ACCEPTED SOLUTION
Hugonaut
Valued Contributor II
@binjali
I've had great success via the following process,
Step 1. Create a Smart Computer Group for computers you want to target.
Step 2. Create the Configuration Profile for Jamf Connect & Scope to Smart Computer Group from Step 1.
Step 3. Create Policy, Add Script Detailed below to Remove NoMad set to run "Before" & Add Jamf Connect Package. Deploy to /  Scope to Smart Computer Group from Step 1.
: HEADER = <<'EOL'
 Description: Unloads launchagent tasks and deletes all NoMAD related files
  Parameters: $1-$3 - Reserved by Jamf (Mount Point, Computer Name, Username)
EOL
# ABOUT THIS PROGRAM
# NAME
#	removeNomad.sh -- Removes all NoMAD components from computer
# SYNOPSIS
#	sudo removeNomad.sh
#	sudo removeNomad.sh <mountPoint> <computerName> <currentUsername>
# DESCRIPTION
#	Unloads launchagent tasks and deletes all NoMAD related files
## Get the current user
loggedInUser=`/bin/ls -l /dev/console | /usr/bin/awk "{ print $3 }"`
# unload LaunchAgent
launchctl unload /Library/LaunchAgents/com.trusourcelabs.NoMAD.plist
launchctl unload "/Users/$loggedInUser/Library/LaunchAgents/com.trusourcelabs.NoMAD.plist"
# Kill NoMAD process
pkill NoMAD
# Reset Login Window
/usr/local/bin/authchanger -reset
# Remove Files
sudo rm -rf "/Applications/NoMAD.app"
sudo rm -rf "/Library/Managed Preferences/com.trusourcelabs.NoMAD.plist"
sudo rm -rf "/Library/Managed Preferences/$loggedInUser/com.trusourcelabs.NoMAD.plist"
sudo rm -rf "/Users/$loggedInUser/Library/LaunchAgents/com.trusourcelabs.NoMAD.plist"
sudo rm -rf "/Library/LaunchAgents/com.trusourcelabs.NoMAD.plist"
# Let it ride?
#exit 0
________________
Looking for a Jamf Managed Service Provider? Look no further than Rocketman
________________
Virtual MacAdmins Monthly Meetup - First Friday, Every Month
6 REPLIES 6
mickgrant
Contributor III
Have a look at this post from the Jamf Blog.
https://www.jamf.com/blog/migrating-from-nomad-to-jamf-connect/
Hugonaut
@binjali
: HEADER = <<'EOL'
EOL
# NAME
# SYNOPSIS
# DESCRIPTION
pkill NoMAD
# Remove Files
# Let it ride?
#exit 0
________________
________________
dvasquez
Valued Contributor
Mean for Binjali...
you mentioned creating the configuration profile for Jamf connect? what needs to go into it?
Just wondering, is there a version of this script that targets NoMAD Pro?  this one works great, but it leaves Pro still on the machines that had both installed. (please don't ask me why both were pushed out; i just got here)
dvasquez
Valued Contributor
Ensure your end-user accounts are not mobile accounts. Then remove nomad then install and use the configuration you want and install Jamf Connect. The script below looks to be getting the job done but always test!
