Avid Pro Tools First 19.5.0 in labs
nadeen_n92
New Contributor II
Hello,
I am trying to create a policy for a manged install for Pro Tools in the labs. I was able to create a pkg using a composer snapshot and the software installed successfully. However, we discovered later that one application file is not getting installed through the package "AIR Music Technology" which has the XPAND plugin. So now i can open projects but they all require that plugin and hence no sound is outputted from the application at all...
This is the composer snapshot files:
a3fb0f9d7a534d44accda9336020534b
Anyone was able to successfully deploy the pro tools 2019 first free version in labs?
Thanks
2 REPLIES 2
davidacland
Honored Contributor II
The plugins would normally install in the /Library/Application Support/Avid/Audio/Plugins folder. As long as they are there with the right permissions, they should be working.
It might be the packaging method that is the root cause. Although it's older, this thread is still valid: https://www.jamf.com/jamf-nation/discussions/14327/need-help-packaging-pro-tools-11#responseChild870...
skinford
Contributor II
@davidacland Hope all is well, do you know if this script is still working for Pro Tools 2020.5.0?
I wish that Pro Tools just did a standard install, for that matter there are several installers that go crazy on you. Not following standard lines. Thank you for any assistance, David!
