Captive Portal Issues
ChrisTech
Contributor
I am having an issue that I think is somehow related to Safari and our proxy. We have had several reports of users traveling off-network and having issues with captive portals. The Captive Network Assistant.app window appears but it's blank and says: "The webpage couldn't be loaded". If I open Chrome or Firefox, and go to https://captive.apple.com then the Captive Portal appears and I can do whatever I need to access the WiFi SSID. If open Safari, I am unable to get to https://captive.apple.com. Has anyone run across this issue? I'm assuming the Captive Network Assistant is using Safari to try to show the Captive Portal...
5 REPLIES 5
AJPinto
Honored Contributor
I would suggest opening a ticket with Apple. However Apple is going to tell you the issue is with the providers of the captive portals. In my experiences I have noticed Safari's website compatibility is fairly horrible among modern browsers. I do not restrict Safari but I do discourage its use.
AdamGMain
New Contributor
Are you running Ventura by chance? I am running into the same issue on Ventura. If I deploy a Jamf configuration for our Securly SmartPAC proxy, I can't access captive portals. However, if I set up the proxy and the ssl certificate manually, it works without issue. I noticed under the Mobile Device configuration, under the Global HTTPS Proxy settings, there is an option to  "Allow bypassing proxy to access captive networks" settings that you can check. I'm wondering with Ventura's switch to a mobile settings interface, if the Computer Configurations side of the proxy configuration in Jamf needs to update this switch somehow.
sudoErase
New Contributor III
You should try using http://captive.apple.com instead of https
DaneLG
New Contributor II
I've had the same issue for a while now.  Hoping that someone has found a solution...
Jaykrishna1
Contributor II
I am also having the same issue and additionally, we are also coordinating with our DLP provider DG.
