Change max. Users on Shared iPads
wabeit
New Contributor
We currently use shared ipads on which a maximum of 5 user profiles are stored. Is there a possibility to change this number without having to set up the device again?
3 REPLIES 3
MattAebly
Contributor II
Contributor II
Good Morning, Patrick,
That setting is enforced right away during the Setup Assistant, so the only way to be able to cache more users would be to wipe the device and enroll it through a PreStage where that number is changed. It essentially partitions up the device during the Setup Assistant. I'll also throw some caution that the more users we have cached with the Shared iPads, the less storage each user would have.
Matt
wabeit
New Contributor
Thank you Matt,
yes that's our problem. The ipad memory is slowly running full, iOS udpates can't be installed anymore. Currently 5 users are saved. I had hoped there was another possibility than a new installation.
Regards
cpominville
Contributor
I have seen an iPad get full with 6 users and it was only one user causing it all. And I am not even sure if it was for real or a bug in the system with that one user. Kids are in JK, so how much stuff could that kid possibly have???.
However, moving forward, I think iPads will be a great success in schools when ALL apps keep their data in the cloud. Either apples iCloud or the Apps own cloud. Already works like that for pictures and that is a GREAT thing.
