How to publish apps silently using Jamf Pro
Flexmacmgmt
New Contributor II
Hi Team
I want to publish a McAfee agent silently to a MacBook when its get enrolled in JAMF Pro. our expectation is the momonet user enrolls in JAMF automatically(silently) the McAfee antivirus package should get installed on the MacBook.
thank you.
2 REPLIES 2
rickgmac
Contributor
You should just use the trigger enrolment complete.
Maybe have a smart group for machines that don’t have it installed and scope to that group.
Also ensure you deploy a config profile to whitelist kernel extension. Otherwise they will get a pop up to allow it.
Chris_Hafner
Valued Contributor III
Yep! The whitelist profile should get there faster than the enrollment complete trigger can fire off the policy.
