Posted on β01-04-2020 09:05 PM
I'm trying to come up with a list of items to check for someone to do a health check of Jamf.
Do you all have any other things to check?
Some ideas so far are:
Check Pre-Stage settings
Remove unused:
1. Scripts
2. PKGS
3. Printers
4. Remove old devices
5. Polices
6. MDM profiles
7. Check patch polices
8. Remove any Unmanaged Devices
Check restricted software polices
Clean up smart groups
Clean up static groups
Posted on β01-05-2020 02:46 PM
@kerickson You might want to re-create this thread with a different subject, say something like "Jamf Pro Spring Cleaning". The words "Health Check" in conjunction with Jamf Pro usually refer to determining if the JSS app is running: Jamf Pro Health Check Page
Posted on β01-05-2020 05:31 PM
Take a look at Spruce on Github, repo link
Posted on β01-06-2020 08:29 AM
@tlarkin Thanks I have used that script. Really trying to build this as a service for future clients.
