Location data not updating when reconing macs
  • April 17, 2012
  • 8 replies
  • 26 views
bentoms
Forum|alt.badge.img+35
Hi All,
Since updating our JSS to the release candidate of8.5 location data is not being updated when reconing macs, we have since upgraded to 8.51 & still we have the issue.
If I run:
sudo jamf recon -realname Ben
On any managed mac, the real name does not get updated in the JSS. JAMF support have confirmed this issue when restoring a backup of my DB.
Anyone else seeing this?
Also, (& possibly related) advanced searches have not worked for us since 8.5.. i have been advised that these will work come 8.52.. but wondering if anyone else on 8.51 is having the issue if they can run the above command & see if it works for them.
TIA!
bentoms
  • April 18, 2012
Guess it's just me?
Location data can be manually updated in MySQL, just not through recon.. i.e. running the below will not update the location data on a client.
sudo jamf recon -endUsername loggedInUser -realname userRealname -email userEmail -position userPosition -phone userPhone -department userDepartment
  • May 1, 2012
We also stumbled on this today! We are trying to find a way to get users to register their computers without running the recon.app. It seems to work with the assetTag verb, but that seems to be the only one that works.
Any ideas on how to do this?
bentoms
  • May 1, 2012
Sadly not, I do have a defect ID for this though: D-002843.
Our JSS is on a Mac 10.7 server, we 1st saw this issue @ 8.5 & am still seeing it @ 8.52.
Please contact support to have them test.
bentoms
  • May 1, 2012
Just heard back from support.. seems to be an issue with our NW segments..
do you have an all encompassing segment?
bentoms
  • May 1, 2012
nvm the above.. it's actually when overriding departments/buildings via network segments.
bentoms
  • May 3, 2012
received this update last night from JAMF support:
So the defect # has changed to D-002867 as a couple more have seen it and another support specialist documented how to get it to "break" from scratch. So, keep an eye out for that in release notes.
Forum|alt.badge.img+20
  • May 24, 2012
any update on this ?
From what you guys are saying you can not manually update the info with recon. Is that true? Or is this still a defect in 8.52
jescala
  • July 13, 2012
We're also having this problem. Is an interim fix available or do we need to wait for the next release?
