Moving from Centrify to JAMF Pro & NoMAD/NoLoAD.
  • June 17, 2019
  • 0 replies
  • 13 views
Hi folks, we had used Centrify to manage our MACs for quite sometime and recently had switched to JAMF Pro along with NoMaD and NoLoad(Password sync) to manage our macbooks going forward. One of the main reasons for switching was because Centrify would often disconnect from the Domain Controller and our Engineers would stay locked out of their Macbooks & could not change passwords.
Albeit, we had a rough onboarding and things were just not as smooth as we thought and there are a couple of issues still preventing us from rolling this out to our organization.
We had a very stubborn,quirky issue where after push out NoMad/NoLoad and their .plists and settings we have found upon reboot will not allow any user in except the administrator. Instead the intended user will get an infinite login loop and NoLoAD screen clears the username/password fields.
Here are our plists that are pushed out to /Library/ManagePreferences Folders.
FindOutFileVault.sh
!/bin/bash
Travelling Tech Guy - 7/12/18 - V1.0
Script created as proof of concept for blogpost https://travellingtechguy.eu/script-secure-tokens-mojave
The idea is to run this prior to enabling FileVault remotely.
This to ensure we have the correct Secure Tokens in place in case you want to manipulate Secure Tokens with an 'IT Admin' accouont later.
Mainly to avoid ending up with a FileVault Enabled Mac, with only a tokenised non-admin enduser.
Script below uses $4 and $5 to pass the "IT Admin" credentials, but I would recommend to have a look at the GitHub link below to add more security.
Encrypt Admin credentials passed via script in Jamf Pro: https://github.com/jamfit/Encrypted-Script-Parameters/blob/master/EncryptedStrings_Bash.sh
Flying Dutch Sysadmin - 23/01/19 - V1.2
Added Checks : - Check if an admin account exists, and if it does if it is admin , if not the script fixes it.
Echo statements provided for troubleshooting.
AS ALWAYS: script provided AS IS. Mainly a proof of concept for the above blogpost. TEST and EVALUATE before using it in production.
Check if a User is logged in
if pgrep -x "Finder"
&& pgrep -x "Dock"
&& [ "$CURRENTUSER" != "_mbsetupuser" ]; then
additional Admin credentials
addAdminUser=_administrator
add encryption
addAdminUserPassword=n3xt261JUM9
Check if the admin provided exists on the system
if [[ $("/usr/sbin/dseditgroup" -o checkmember -m $addAdminUser admin / 2>&1) =~ "Unable" ]]; then addAdminUserType="LiesItDoesNotExists" else addAdminUserType="AllGood" fi if [ "$addAdminUserType" = LiesItDoesNotExists ]; then echo "Admin user status: LIES! it did not exist go check the data" && exit 20 else echo "Admin user status: You where right! the account did exists"
Check if our admin has a Secure Token
if [[ $("/usr/sbin/sysadminctl" -secureTokenStatus "$addAdminUser" 2>&1) =~ "ENABLED" ]]; then adminToken="true" else adminToken="false" fi echo "Admin Token: $adminToken"
Check if $addAdminUser is actually an administrator
if [[ $("/usr/sbin/dseditgroup" -o checkmember -m $addAdminUser admin / 2>&1) =~ "yes" ]]; then AdminUserType="ItWasAdmin" else AdminUserType="LiesItWasNotAdmin" fi echo "Admin Account Status: $AdminUserType"
Fixing the admin to make it admin
if [ "$AdminUserType" = LiesItWasNotAdmin ]; then dscl . -append /groups/admin GroupMembership $addAdminUser echo "Admin Promo status: It wasnt admin but now it is" else echo "Admin Promo status: No Action Needed " fi
Check if FileVault is Enabled
I'm not using this variable in the rest of the script. Only added it in case you want to customise the script and enable FileVault at the end if 'fvStatus' is false
if [[ $("/usr/bin/fdesetup" status 2>&1) =~ "FileVault is On." ]]; then fvStatus="true" else fvStatus="false" fi echo "FV Status: $fvStatus"
Check Secure Tokens Status - Do we have any Token Holder?
if [[ $("/usr/sbin/diskutil" apfs listcryptousers / 2>&1) =~ "No cryptographic users" ]]; then tokenStatus="false" else tokenStatus="true" fi echo "Token Status $tokenStatus"
# Get the current logged in user userName=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + " ");')
# Check if end user is admin
if [[ $("/usr/sbin/dseditgroup" -o checkmember -m $userName admin / 2>&1) =~ "yes" ]]; then userType="Admin" else userType="Not admin" fi echo "User type: $userType"
# Check Token status for end user
if [[ $("/usr/sbin/sysadminctl" -secureTokenStatus "$userName" 2>&1) =~ "ENABLED" ]]; then userToken="true" else userToken="false" fi echo "User Token: $userToken"
# If both end user and additional admin have a secure token
if [[ $userToken = "true" && $adminToken = "true" ]]; then echo "All is good!" exit 0 fi
# Prompt for password echo "Prompting ${userName} for their login password." userPass="$(/usr/bin/osascript -e 'Tell application "System Events" to display dialog "Please enter your current password" default answer "" with title "FileVault Configuration" with text buttons {"Ok"} default button 1 with hidden answer' -e 'text returned of result')"
# Check if the password is ok passDSCLCheck=dscl /Local/Default authonly $userName $userPass; echo $?
# If password is not valid, loop and ask again while [[ "$passDSCLCheck" != "0" ]]; do echo "asking again" userPassAgain="$(/usr/bin/osascript -e 'Tell application "System Events" to display dialog "Wrong Password!" default answer "" with title "Login Password" with text buttons {"Ok"} default button 1 with hidden answer' -e 'text returned of result')" userPass=$userPassAgain passDSCLCheck=dscl /Local/Default authonly $userName $userPassAgain; echo $? done
if [ "$passDSCLCheck" -eq 0 ]; then echo "Password OK for $userName" fi
# If additional admin has a token but end user does not
if [[ $adminToken = "true" && $userToken = "false" ]]; then sysadminctl -adminUser $addAdminUser -adminPassword $addAdminUserPassword -secureTokenOn $userName -password $userPass
echo "Token granted to end user!"
diskutil apfs listcryptousers / fi
# If no Token Holder exists, just grant both admin and end user a token if [[ $tokenStatus = "false" && $userToken="false" ]]; then sysadminctl -adminUser $addAdminUser -adminPassword $addAdminUserPassword -secureTokenOn $userName -password $userPass
echo "Token granted to both additional admin and end user!"
# If end user is an admin Token holder while our additional admin does not have one
if [[ $userType = "Admin" && $userToken = "true" && $adminToken = "false" ]]; then sysadminctl -adminUser $userName -adminPassword $userPass -secureTokenOn $addAdminUser -password $addAdminUserPassword
echo "End user admin token holder granted token to additional admin!"
# If end user is a non-admin token holder and our additional admin does not have a Token yet
if [[ $userType = "Not admin" && $userToken = "true" && $adminToken = "false" ]]; then echo "Houston we have a problem!" #Here you could update an extension attribute (API CALL) to group problematic Macs in a smart group. #The only workaround to fix this is to promote the end user to admin, leverage it to manipulate the tokens and demote it again. #I tried it, it works and it does not harm the tokens. dscl . -append /groups/admin GroupMembership $userName echo "End user promoted to admin!"
sysadminctl -adminUser $userName -adminPassword $userPass -secureTokenOn $addAdminUser -password $addAdminUserPassword echo "End user admin token holder granted token to additional admin!"
dscl . -delete /groups/admin GroupMembership $userName echo "End user demoted back to standard!" #exit 1 fi
Here you could call a custom trigger to run a jamf Policy enabling FileVault
or update smartgroup via 'jamf recon' to push a Configuration Profile to enable Filevault via an extension attribute (API CALL.
In case you are running this script on Macs where FileVault was already enabled, your admin account will still get a Secure Token,
... unless your non-admin end user was the only token holder.
However, creating Secure Tokens post FileVault enablement does not make the account show up ad preBoot automatically.
... you will need to run the following command to do so.
diskutil apfs updatepreBoot /
This compared to the fact that enabling FileVault does add all existing Secure Token Holders automatically to the preBoot Filevault enabled users
else echo "No user logged in" exit 1
Menu.nomad.login.ad.sh
! /bin/bash
Install the pkg files found in a temp location
for PKG in $(ls "/private/var/csg/Install/$csgfile/" | grep "pkg$")
do
/usr/sbin/installer -pkg /private/var/csg/Install/"$csgfile"/"$PKG" -tgt / -allowUntrusted
Then it will remove the installers
rm -Rf /private/var/csg/Install/"$csgfile"/"$PKG"
done
I remove any old existing ones it makes changes easier
rm -Rf /Library/Preferences/menu.nomad.login.ad.plist
mkdir /var/db/NoMADLogin/
Variables
AD_domain=Domain123.com
BackgroundImage=/private/var/db/NoMADLogin/Desktop.jpg LoginLogo=/private/var/db/NoMADLogin/Logo copy.png Placeholder=FirstintialLastname@nextjump.com
defaults write /Library/Preferences/menu.nomad.login.ad.plist ADDomain Domain123.com
defaults write /Library/Preferences/menu.nomad.login.ad.plist AdditionalADDomains -boot YES
defaults write /Library/Preferences/menu.nomad.login.ad.plist LocalPasswordSync -bool true
defaults write /Library/Preferences/menu.nomad.login.ad.plist ADDomain "$AD_domain"
defaults write /Library/Preferences/menu.nomad.login.ad.plist BackgroundImage "$BackgroundImage"
defaults write /Library/Preferences/menu.nomad.login.ad.plist LoginLogo "$LoginLogo"
defaults write /Library/Preferences/menu.nomad.login.ad.plist EULAText -bool No "$EULA"
defaults write /Library/Preferences/menu.nomad.login.ad.plist EULATitle "$EULA_Title"
defaults write /Library/Preferences/menu.nomad.login.ad.plist EULAPath "$EULA_Path"
defaults write /Library/Preferences/menu.nomad.login.ad.plist CreateAdminUser -bool Yes
defaults write /Library/Preferences/menu.nomad.login.ad.plist CreateAdminIfGroupMember -array 'Tech Support' 'Domain Admins'
defaults write /Library/Preferences/menu.nomad.login.ad.plist DemobilizeUsers -bool Yes
defaults write /Library/Preferences/menu.nomad.login.ad.plist UsernameFieldPlaceholder "$Placeholder"
defaults write /Library/Preferences/menu.nomad.login.ad.plist KeyChainAddNoMAD -bool Yes
defaults write /Library/Preferences/menu.nomad.login.ad.plist KeychainCreate -bool Yes
defaults write /Library/Preferences/menu.nomad.login.ad.plist BackgroundImageAlpha "1"
Backup existing security authdb settings
security authorizationdb read system.login.console > /private/var/db/NoMADLogin/evaluate-mechanisms/console.bak
Write NoMADLoginAD security authdb mechanisms
security authorizationdb write system.login.console < /private/var/db/NoMADLogin/evaluate-mechanisms/console-ad
/usr/local/bin/authchanger -reset -AD
truscourcelabs.sh
! /bin/bash
defaults write /Library/Preferences/com.trusourcelabs.NoMAD ADDomain "Domain123.com"
defaults write /Library/Preferences/com.trusourcelabs.NoMAD LocalPasswordSync -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD KerberosRealm NEXTJUMP.COM
defaults write /Library/Preferences/com.trusourcelabs.NoMAD GetCertificateAutomatically -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD RenewTickets -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD UserSwitch -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD LoginItem -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD UseKeychain -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD SignInWindowAtLaunch -bool true
defaults write /Library/Preferences/com.trusourcelabs.NoMAD UPCAlert -bool true
