Hi All,
I have a problem with smart groups after upgrading to 9.3. I upgraded yesterday (and haven't changed anything else).
Now, every time a device updates, I get notifications that it has been removed from the smartgroup, then almost immediately I get a notification that it has been added to the smartgroup.
The smartgroup in question checks to see whether specific profiles are installed.
I have noticed many devices, it seems as though the current inventory is deleted for several seconds before the new inventory is added and this removal then addition of the inventory is causing these emails.
This is of considerable concern as I use smart groups to define whether users are entitled to have their WiFi certificates and authentication installed - if the system decides to remove their WiFi then tries to add it again then the re-addition will fail.
How do I prevent these deletions / additions?
Cheers,
Chris.
