Manually converting VPP Codes not in excel sheet to Managed Distribution
jgwatson
Contributor
I was just given a bunch of individual VPP codes for some apps in an email (not excel spreadsheet), to distribute to some teachers. I want the teachers to be able to preview the apps, and then I will share them with other teachers.
How do I convert these individual codes so I can manage them? Do I need to convert them into the excel spreadsheet format? Hoping to hear about an easier way.
Thanks
1 REPLY 1
GabePPS
Valued Contributor III
You can email apple to ask them to convert your whole account of VPP codes to managed distribution. I just did this with about 30 VPP apple ID's and converted about 13,000 apps. Its all or nothing though. You cannot switch back, although I don't think anyone would want to.
itunes_vpp_support@apple.com
Gabe Shackney
Princeton Public Schools
Gabe
